Thread: Full Machine Design/Display
I wrote a free plugin that gives you DXF and STL output from the free version of Sketchup,
http://www.guitar-list.com/download-...les-dxf-or-stl
Nathan
14-05-2009 #2Lee, very flattered that you picked the image of my router!What I would like to know is what programs you use to design in?
I use the free version of Google Sketchup. Sketchup is a great! It's not engineering software, but you can change the default accuracy from 1mm to 0.01mm which helps. It's amazing for free! :-)
"Components" are the best. Every copy of a component in the model will change when you edit just one of them. Want to add a chamfer to a bearing that appears 50 times in your model? 60seconds of work! :-)
Nathan - THANKYOU so much for the sketchup plugin. I was about to start learning to use the emachineshop CAD program to generate dxf files, but no need now! I'll install it and have a play at the weekend...I wrote a free plugin that gives you DXF and STL output from the free version of Sketchup,
Cheers!
Some thoughts on cnc machine design principles. . .
By routercnc in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 09-10-2020, 10:59 AM -
FOR SALE: Full machine / setup for sale
By kingcreaky in forum Items For SaleReplies: 10Last Post: 18-07-2013, 08:57 AM -
A concept design for a cnc machine
By madprof1 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 07-12-2012, 10:40 PM -
CNC milling machine full support required
By Rebekah_harper in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 26-05-2012, 10:57 PM -
FUNdaMENTALS of machine design
By Ross77 in forum General DiscussionReplies: 1Last Post: 13-08-2010, 12:58 AM
