12-07-2014 #5
Yes, Jonathan, I'd usually agree with your logic.
However, this is how I understand it so far, the tubes have a recommended trigger and running voltage. The power is controlled by PWM, so the voltage doesn't change for a tube and PSU pair. But higher and lower power tubes require a matched PSU. The tube lengths are specific to each power level. The 40w and 50w seem to be very close, so I am assuming it will be ok. (you know what ASSUME means ! ).
I wondered if a lower trigger and working voltage in the 40w PSU would be enough to run the 50w tube ... think, putting a small engine in a big car ! ... if it does manage to fire the laser .. might it shorten the life of the PSU ?
Just picking brains, before I try it anyway ! lol
unless , of course, anyone has a valid reason why I shouldn't :)
Help with some tube please
By Fivetide in forum Marketplace DiscussionReplies: 1Last Post: 24-05-2014, 12:54 PM -
Box section tube straightness
By jimbojones1000 in forum Metalwork DiscussionReplies: 7Last Post: 18-02-2014, 04:11 PM -
Ali rectangle tube 120 mm x 60 mm x 4mm / 5 mm looking for off cuts please :)
By Fivetide in forum Marketplace DiscussionReplies: 5Last Post: 29-07-2013, 08:37 PM -
NEW MEMBER: CNC Tube Bender guy, here!
By Tinine in forum New Member IntroductionsReplies: 0Last Post: 10-02-2013, 04:46 PM -
WANTED: Bit OT - 15mm od seamless tube?
By m_c in forum Items WantedReplies: 1Last Post: 11-07-2012, 09:23 PM
