  1. #29
    Hi Irving, i have stated already, my BoB is only 5 volts, are you now saying i can wire a 3 wire sensor direct on to the Bob?
    Ray
    Quote Originally Posted by manofgresley View Post
    Ray
    You need NPN NC switches. I'm fairly sure, but not 100% that your BOB doesn't have opto-isolated inputs (the manual is useless), but maybe someone can confirm this. Do you have a voltmeter/multi-meter? If so measure the voltage from limit switch input to ground (with power on the BOB). If its more than 2v then its probably not opto-isolated and if it 5v it probably has an internal pull up. In which case wire the switch as:
    Brown: +12 or 24v power supply
    Black: To BOB limit input
    Blue: to Ground on BOB limit input AND to Ground on 12/24v supply.
    Now you need to decide for X and Y if home is at one end of table travel or in the middle (Z home is always the top). Since proximity sensors work on approach of ferrous material, if Home is in the middle of the movement range, Mach has the problem of knowing which side to approach the sensor from since approaching from either side will give the same result electrically but will be offset by potentially 8mm mechanically. I don't know how you tell Mach to home from a given direction, but I'm sure it can be done...
    edit: Eddy types faster lol. But I want to reiterate the proximity sensor accuracy previously discussed is for material approaching axially (i.e. towards the end of the sensor). For this requirement the approach will have to be radially, i.e. across the face
  1. Limit switch issues?!?
    By jonbabbz in forum General Electronics
    Last Post: 06-02-2014, 07:37 PM
  2. Another Home - Limit switch question
    By Cube3 in forum General Electronics
    Last Post: 26-12-2013, 07:51 PM
  3. One limit switch per axis
  4. Limit switch Cable ...
    Last Post: 17-01-2011, 04:37 PM
  5. Limit switch's - best configuration?
    By HiltonSteve in forum General Electronics
    Last Post: 13-08-2009, 01:26 PM
