Thread: Plcm-e4
    Quote Originally Posted by Tumblebeer View Post
    I realise this is a bit of a ramble, but I'm rather confused at the moment, trying to decide what to get. Cost is a bit of a concern, and I wouldn't want to spend as much on a bob as I do on the motion controller as it seems like some people do.
    Any tips?
    Don't short cut the BOB esp with a Motion control card. BOB's are the single biggest bottleneck and pain in the arse if poor quality.
    I'd enquire about the E4 but got a feeling it's still in R&D.
    The B1 is just a BOB but it's designed to take full advantage of the E3 and allows full use of all the I/O. It's essentially 2 Bob's in one with PWM spindle control.
    If you don't need all the I/O the E3 provides then you can get away with just using the PLC6x or the PLC4x-G2. The G2 provides PWM spindle control the 6x doesn't.
    If your going for the ESS then I'd strongly suggest you go for the PMDX126.
    I was getting a bit confused about this as well, when I was looking at the Zapp site earlier (and especially as I haven't found decent English documentation for these devices). Thanks for the additional info.
    One more question, though - when these boards talk about PWM spindle speed control, I am assuming that they have some kind of PWM->true analogue converter on board, which takes a PWM speed signal from Mach3 and gives a 0-10V (usually) signal that connects directly to the VFD. Is that right? Nothing else needed for Mach3 spindle speed control?
    - Brian
    Yep that's correct just set mach3 to output PWM and away you go.!
  1. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
  2. Purelogic Tiny Mach3 USB motion controller PLCM-LPT2
    Last Post: 21-08-2012, 08:22 AM
