15-07-2014 #5
Hole in plastic. Detail in the hole. Hot glue gun.Glue it. Wait 1 min. Do the job. Spray can filled with alcohol/rubbing or whatever/. Spray on the hard hot glue. Unglues like miracle. No traces on job or board .Thats it.
I use mostly hot glue to hold almost anything. Double sided tape is pain in the a**s to clean. Even when i used very very thin one/ used for photo prints to fix on a support and lexan top/ it makes a mess. Especially if you have a cut through or hole, the last mm should be very slow or bit breaks in the goo.
Z-Plunge advice sought...
By Wal in forum Machine DiscussionReplies: 3Last Post: 17-11-2013, 01:43 PM -
Advice Sought for Lathe
By Washout in forum Lathes, Lathe Rebuilding & ConversionsReplies: 13Last Post: 13-11-2013, 12:32 AM -
Holding down sheet material.
By jcb121 in forum Machine DiscussionReplies: 3Last Post: 03-07-2013, 12:11 AM -
holding mdf down to bed
By kell in forum General DiscussionReplies: 8Last Post: 13-07-2012, 02:59 PM -
Help and Advice sought about new motor for my mill
By alanb in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-01-2012, 08:04 PM
