    Hi Charlie,
    Good to read that you've switched to the conventional Z axis, although I hope you've done it due to understanding the problem rather than peer pressure.
    To to lay it out again, using the calculations for the simplified example previously shown:
    Conventional Z axis deflection of between 0.19um - 10um depending upon Z axis extension
    Unconventional Z axis deflection of 10um - FIXED (i.e. the worse case conventional at all times)
    Your unconventional sketch in post #39 looked like it might get around the 'tuning fork' problem but it would not be very practical as it was drawn at full extension and this meant cutting would be up near the gantry! Your only option for practical work would be to drop the spindle down in the mount to hang down out of the clamp, but I think this would not be especially stiff. Your only other option in the design would be to raise the lowest bearing block to allow the Z axis to drop further but then you are back around the loop of an unconventional Z axis as per the above.
    Hi Charlie,
    Hi, TBH I changed because that many people can't be wrong...Can they? :-P
    I understand what they are saying, although I don't fully agree because although with the conventional method at miniumum travel it is stronger because the tool tip is about 40mm from the bottom bearing block, at max travel it would be far more flimsy than my design, there must be a 'magic' point on Z where aluminium can be machined ok and if I knew that distance then I could try and work it out in my design.
    None of that matters now ( I think!) because I have gone back to the drawing board with a completely different design using a fixed gantry based off a Video Jazz posted in another thread where the Y axis raises and lowers with Z. It may come to nothing and I may change my mind again!
    Jazz, I know what you say about jack of all trade machines, it would help if I knew what I intended to use the machine for but I don't! I like working with wood as much as metal, I think now I am leaning more towards metal machining because more practical things can be made but I would also like to have a play with my artistic side with woods and plastics, This was why I was going for a router type build initially but the size required for some of my wood type projects have put a bit of a dampener on that :-( unless I go for a vertical machine like yours.
    Cheers, Charlie
    Quote Originally Posted by CharlieRam View Post
    Well don't be put off by anything we say and always go with your gut feeling I would say. but I'll tell you now thru experience not guessing that your wrong.
    There is a magic number.? On my machine.!! It's 0-50mm and past this finish deteriates to point that's not acceptable to me, but that doesn't mean my number will match your machines number.!! . . . . This is essentially the problem in that every machine is different and the finish you get will be a direct results of how strong and how good the design along with many other variables. This also holds true for feeds n speeds to some degree.? Each machine will perform different for same material.!
    If it's the one I'm thinking about then it's a good layout and very strong. I've got a much larger version part built using 150mm box section for my self just can't get around to finishing it. (Well it's more starting than finishing.!!)
    Cheers, Charlie
    If your going for metal then forget the moving gantry design. Go with the design above and make it massively strong. To be honest if your wanting to cut metal then I'd suggest you keep an eye out for a large Milling machine and convert to CNC or look for used or knackerd CNC VMC and convert to Mach3/Linux cnc.
    Only few weeks ago there was a Cincinnati CNC VMC on ebay for £1400 24 tool changer and full bag of tricks. At that money even if screws and rails where worn out you could convert control and replace components for same money or not much more than building a DIY machine for cutting steel.!
    To give an example I picked this CNC Mill up at scrap value. 1100 x 500 x 500 cutting area. DC servo's, 7.5Kw Cat40 spindle, Was fully working apart from needing PSU for the out dated Hindeman control which at some point around 2060 when get time I'll be replacing with Mach3 and CSlabs Analog controller. DIY isn't always the best option esp when you get into milling steels.!
ID:	13163Click image for larger version.
    I see three problems with buying a mill.
    1. I couldn't say I made it myself ( big one)
    2 It's bloody huge! I would never get it in my back garden and even if I did, I wouldn't have anywhere to put it.
    3 Divorce is expensive :-)
    Cheers, Charlie
    Well easy replys's to these Commnets.!!
    #1 It would be an achievement in it's self for someone new to CNC to Retrofit something like this and they could be proud if they did it.!
    #2 This should tell you everything you need to know about what's required to cut steel.!! . . . . It's nearly 3000KG and mostly cast iron.
    #3 Turned out to be the Best thing that ever happened and worth every penny(And there where many 1000's. . Lol).
    Well....
    Ive changed my mind again! not sure whether to start another thread now.
    I have decided that I am going to buy a mini milling machine for machining steels and simple plates ect which will help me build my router which will therefor be used mainly for woods and plastics with maybe the occasional bit of aluminium if I decide to convert the mill, I am thinking something like the ama25lv, its about the right size to get behind my shed!
    This means I am back to idea 6 albeit with a conventional Z but I have measured the area where I am building my 'workshop' and once I have fitted soundproof / insulation I will be left with a working area of about 1.6m wide by 4m long. If i install my router flat then that will leave only 60cm at best to get past the machine, Is this too tight? it could be quite dangerous with the gantry swinging back and forth!
    My other option would be to install it against the wall length ways or height ways and bolt to the floor, height ways would work best for me but that depends on the recomended gradient and the lump of concrete its bolted to!
    Can you take a look at my Y carriage arrangement and let me know if it will be OK, I moved the lower carriages together by 50mm and the upper ones 50mm further apart so it utilises the space on top of the beam and gives me some of the movement back which was lost by using the conventional Z.
    Things to do:
    1. Build my shed/workshop
    2. Buy a milling machine
    3. Build my router!
    4. convert the milling machine?
    Cheers, Charlie
    Well here it is, Idea 9 , mainly for woods/plastics but also hoping to do a bit of aluminium or cast iron work when I modify my mill (which I havn't actually got yet! )
    All bits in blue are steel, the gantry is built using 80x40 4mm box section aluminium with a 20mm plate across the front, the X axis rails will be 80 x 40 steel with 5mm of resin for leveling but I am not sure whether to go 3mm or 4mm steel thickness (is 3mm enough, I will go 4mm if its weldable??) the frame is 50x50 3mm steel and I plan on putting 4"x1" aluminium box section running the length of the bed with a 10mm alu plate on top of that drilled and tapped.
    To manufacture the gantry I plan to machine the front plate, leaving a little for finishing. The aluminium box section will then be bolted together, solid aluminium blocks will be machined to fit in the ends. I am then hoping to lightly skim the X rail seating faces square to the front face and also lightly skim the front face before attaching the 20mm plate. I will then skim the profile rail support faces on the alu plate. What do you reckon?
    The frame and X rails are all one component and even though I haven't welded before I am hoping to get the top face for the rails within 5mm so that the epoxy leveling will do its job! I realize that I am going to have to shim the ballscrew mounts so that they run parallel with the rails but is there anything else I should watch out for?
    I have included the sketchup file for anyone wanting to tear it apart for scrutiny and as always appreciate any feedback as to why it will/won't work.
    Cheers, Charlie
Name:	idea 9 front.jpg
ID:	13335   Click image for larger version.
Name:	idea 9 side.jpg
ID:	13336   Click image for larger version.
Name:	idea 9 top.jpg
ID:	13338   Click image for larger version.
    Attached Files Attached Files
  1. Design of small router (700x900) for aluminium
    By Edward in forum Gantry/Router Machines & Building
    Last Post: 16-12-2017, 07:34 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  4. CNC Frame Design Help
    By zhenning in forum Gantry/Router Machines & Building
    Last Post: 26-12-2015, 05:44 PM
  5. BUILD LOG: Steel frame cnc router design/build
