07-07-2019 #181
5mm distance from the hard stop will function fine as the motors stop very quickly. If it was a home switch you might want a bit more as the machine over travels a bit.
Only thing to think about is if you can get your finger trapped.
07-09-2019 #182
So I had some issues with my AXBB charge pump output but that has now been resolved thanks to some helpful people on here
This means that I have finally been able to make some movement on my machine however I'm not entirely happy with it.
What kind of rapid speeds would you expect on nema 23 and 70v driver/psu?
I may have to go for twin motors on the X axis or a higher power nema 34 as that seems to bind if I go above 12000 units per minute(I am running at 10000 to be safe) whereas y axis goes upto 17000 units before binding(running at 14000). The z axis is only around 8000 but I assume that's because of the ballscrew pitch.
Anyway, it's looking promising but there may be room for improvement.
The y axis is smooth one way but seems to have a judder when rapid in the opposite direction...any ideas?
The X axis sounds gratey in both directions ! I'm thinking it may be sounding worse because it runs on the steel box section and that may be amplifying the sound?
https://youtu.be/Jv9x7rc4N-8
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 08-09-2019 at 08:26 AM.
08-09-2019 #183
Hi Charlie, don't know anything about your setup so might be way off here.
If you are using a Single nema23 with 70v to drive 2 x 10mm pitch screws then you're doing well to get 10M/min. Or if you're using single Nema34 with only 70V you still won't get much more than 10Mtr/min. You'll need more Volts for Nema34 to get higher rpm.
Now 2 x 23 will get you little more speed but my question would be WHY.? You can't cut many materials higher than 10mtr/min, woods etc will be much lower feeds and the machine isn't massive so 10mtr/min rapids will still get you end to end quick enough.
08-09-2019 #184
Hmm...well I suppose the need for speed is more down to seeing the rapids from the machines at work! Yes I know they cost more like 1 mill each but y'know
I suppose the real answer is I'd of liked the X and Z to run at the same speed....not a deal breaker and maybe in the future ill upgrade the X axis but I'm happy with it for now. I tweaked the speeds and acceleration values today and it's a pretty speedy little thing
soon be making a cut.
Sent from my SM-G920F using TapatalkLast edited by CharlieRam; 08-09-2019 at 08:14 PM.
08-09-2019 #185
11-04-2020 #186
Long time no post so I'd like to thank you all for your help during this build and give a little update. I decided to upgrade the x axis to use a slave drive, firstly just to get a little more speed from it but secondly because the length of the single belt worried me a little! I managed to blow the charge pump output on my AXBB twice but I have since repaired it and had no issues since. I have done a few test cuts and am quite happy with it so far although I have noticed that the x axis motors resonate quite badly on low revs. The drives are set identically to the Y and Z with the only difference being it has both X and A slaved. Any ideas? Also I'd like to wire up the fault output on the drives and am a little unsure of how to do it
Here's a linl to a youtube vid pf the machine doing a bit of the carving below
https://youtu.be/71zmWimvsMc
Thanks again...i couldn't of got this far without your help
stay safe everyone.
11-05-2020 #187
Congratulations on completing your machine - having just read through your complete build log, I was at many points not expecting it to end with this triumphant post!
I hope you would consider entering your machine details here. Hopefully someone more experienced will be along to answer your questions. As soneone plotting their own build, always keen to hear reflections and lessons from those who have made it through.
Best wishes
Andrew
Design of small router (700x900) for aluminium
By Edward in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-12-2017, 07:34 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
CNC Frame Design Help
By zhenning in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-12-2015, 05:44 PM -
By CraftyGeek in forum DIY Router Build LogsReplies: 110Last Post: 06-05-2015, 10:00 PM
