12-10-2015 #111
I don't know how old the rods are cos my mate who lent me the welder gave me 3 full packs of different sized rods. I had another play today and I was able to strike the arc more consistently so maybe just a bit more practice needed.
I will try warming some rods in the oven and yeah I am practising on off cuts ATM. Wouldn't dare try it on my frame yet!
Cheers Charlie
12-10-2015 #112
It's definitely worth getting some nice new rods, they're not that expensive and make all the difference! I had some old rods and was struggling to strike an arc and I got fed up and bought a bix of new ones. You'll be amazed at the difference...now I'm not a good welder, in fact I'm pretty rubbish (bloody love my grinder!!!!!) but decent rods are a must :)
18-10-2015 #113
One oldschool trick is to strike the electrode and let it stick for a few seconds until it starts to "sweat". Then use it as normal. I would only use this method when emergency and out of good try electrodes...
22-10-2015 #114
Just a quickie to show my progress (Or lack of it!) My welding is improving now, still not great but better than before.
It seems I was upping the ampage to compensate for my complete inability to weld but now I have the hang of it the amps are set right for the rod size and the welds are starting to look like real welds
Cheers, Charlie
28-10-2015 #115
Getting there, welding still looks like pigeon sh*t but at least it looks like it will hold together now.
Cheers, Charlie
Sent from my XT1072 using Tapatalk
12-11-2015 #116
This welding lark is doing my head in! 4 weeks on and all I seem to do is weld, break of the slag and clean only to discover it welds on either the plate or box section but very rarely both together, my box section is getting thinner and thinner from grinding back :-( I am now also at the mercy of the weather so got knows when the frame will be finished but I need to make sure my welding's better before I start on the top rails. I keep watching youtube, playing about with different rods, amps and angles, bought a new visor with adjustable darkness so I can actually see what I'm doing but I think I just can't weld!
Cheers, Charlie
12-11-2015 #117
Stick @ it Charlie.
One of the reasons i opted for a TIG setup is that you can see exactly whats going on and you know the two bits are fused.
Frame looks good M8
Regards
Mike
12-11-2015 #118
Cheers, it's just so frustrating going over the same thing again, thinking you've cracked it only to discover its as bad as the last one!
12-11-2015 #119
Charlie, my welding is the same as yours. I think I've cracked it and then lay a weld that's just attached to one piece...just keep at it. Law of averages means that although you might get through lots of grinding discs you'll get there eventually by having more goid welds than bad ones!!
12-11-2015 #120
I think it would be prudent to do some more test welds, try turning up the amps a bit and try to hold a short arc.
Good luck
There are currently 18 users browsing this thread. (0 members and 18 guests)
Design of small router (700x900) for aluminium
By Edward in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-12-2017, 07:34 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
CNC Frame Design Help
By zhenning in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-12-2015, 05:44 PM -
By CraftyGeek in forum DIY Router Build LogsReplies: 110Last Post: 06-05-2015, 10:00 PM
