    Also that Z axis design is bad news. Again check out threads and look at Z axis designs that put the rails on the front plate and bearings on rear. Your design is a constant length lever that won't even reach the bed surface and will give the same amount of flex whether it's at the bottom of top of it's travel. With the other design the lever length is variable dependent on material thickness or distance from tool.
    Hi Jazz, is that Z axis any weaker the way I had it? I am struggling for room and didn't want to compensate by reducing my cutting area, I have gone back to Idea 3 but raised the rails on X. I would still like to use the fourth axis along X and this would allow that, giving me an effective work area of 150mm diameter by whatever length travel I decide on.
    My X rails are 810mm apart, carriages are 250mm apart from outer dimension, Would I suffer from binding if I just had a central ballscrew or would you still recomend one on either side?
ID:	12875   Click image for larger version.
Name:	idea 3 front.jpg
    The normal convention for the Z axis is to have the rails on the front plate and the carriages/bearings on the back plate. This adds stiffness to the front plate which is where the axis most needs it. Also stick with 20mm plate if you can rather than 15mm. With regards to ballscrews two are way better than one, you undoubtedly would get racking with one central ballscrew at that width I would say.
    Neil...
    Build log...here
    Okay so what if I were to make the spindle plate 30mm thick aluminium or 20mm+ thick steel ( I could grind the steel perfectly flat and parallel at work, well within a couple of microns anyway), would that be strong enough to have the bearing blocks the opposite way round or does that method just not work? in fact a lot of the plates could be made of steel which would be easier for me to grind flat as we use mag chucks, it would add weight but also a lot of strength.
    Probably dont want to change too much though as the weight will increase substantially!
    Anyone? Is My idea 3 Z axis just not up to it, will changing the front plate to steel help or not? Just the Z plate, not the x rails as I have mounted them directly on top of the rails.
    Hi Charlie
    I think you are not getting a reply on the z plate as most people have it set up in reverse (carriages on Y plate) so can't give you an opinion.
    If you want to go with the opposite (carriages on Z plate) then you'll need a calculation of 20mm aluminium with reverse mounting (at full reach and home-they will be different which is why that route us preferred) vs forward mounting with 20mm steel and 30mm aluminium (at any reach as they will all be the same stiffness).
    if I get the chance I'll have a look tonight and see if you can recover the stiffness through gauge.
    What is the distance from the lowest Z
    axis bearing to the collet at full Z extension?
    Hi Charlie,
    OK, I've made a few assumptions for dimensions and compared different Z axis options for deflection. The deflections are artificially small because the rest of the machine is grounded, but you can compare the numbers with each other to see the trends.
    1. Shows the conventional layout (carraiges on Y axis plate, rails on Z plate) using 20mm aluminium plate at full extension. This gives 10um.
    2. Shows the same conventional layout as 1 but at almost minimum Z extension. This gives 0.2um. This is 20x stiffer just by raising the job so that cutting is done with the Z axis near the home switch.
    3. Shows the unconventional layout (carraiges on Z plate, rail on Y plate) using 20mm aluminium plate. This is drawn at an arbitrary extension because with this design all extensions have the same stiffness. This gives 10um. You can see that it is the same as 1. But if you need to do a deep cut, or hold a fine tolerance etc. then you cannot raise the Z to increase the stiffness. So, onto your question about recovery . . .
    4. Shows the unconventional layout using 30mm aluminium. This has reduced the deflection to 3um. 3x better than 20mm aluminium, but still nowhere near the best conventional result (2).
    5. Shows the unconventional layout but using 20mm steel for the Z plate. This has a deflection of 3.5um, so about the same as the 30mm aluminium plate. This is also nowhere near the best conventional result (2).
    So, if all of your cutting is done near full extension, and your machine is stiff enough to cut well at that extension, then it does not matter if you choose conventional or unconventional (and both with 20mm aluminium plate) as they are the same.
    But chances are you might not get the finish you want at full extension as you are cutting at quite a distance from the support bearing, and so with the conventional layout you can raise the job in Z and try again. You can stiffen the axis quite a bit by doing this. With the unconventional layout this makes NO difference (in terms of Z plate bending) so you are stuck with it. You can upgrade the Z plate from 20mm to 30mm aluminium and stiffen it a bit more, or go for 20mm steel (works out about the same), and gain an improvement. But you cannot get close to the stiffness improvement of the conventional layout raised close to the home switch.
    I can't tell you which option will be stiff enough for you, but I can say that once you have made the machine if you run into problems and have gone the unconventional route it is difficult to make a significant improvement. Hope this helps.
    Hi Charlie,
    Cheers for that, I am in Egypt atm and the internet in my hotel is dodgy as hell. I will have a play with that spreadsheet (is that the stiffness v7) when I get back because I think the distance to the collet from bottom bearing block is quite a. Bit smaller than 150mm and consistent stiffness should give more predictable results. Cheers
  1. Design of small router (700x900) for aluminium
    By Edward in forum Gantry/Router Machines & Building
    Last Post: 16-12-2017, 07:34 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  4. CNC Frame Design Help
    By zhenning in forum Gantry/Router Machines & Building
    Last Post: 26-12-2015, 05:44 PM
  5. BUILD LOG: Steel frame cnc router design/build
