16-08-2014 #11
Given the short length of your desired travel it will work ok. Bus as you have drawn it, the bit should touch the finished machine bed. Cause lower it will not go obviously. Is it so?
The case is if say you want it to travel 200mm for example or longer , then the 4 blocks on the Z will go higher than the gantry, hence the tuning fork.
Design of small router (700x900) for aluminium
By Edward in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-12-2017, 07:34 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
CNC Frame Design Help
By zhenning in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-12-2015, 05:44 PM -
By CraftyGeek in forum DIY Router Build LogsReplies: 110Last Post: 06-05-2015, 10:00 PM
