  1. #10
    You want to try to avoid welding directly to the X axis box section. You can weld a 10mm plate to the top of each upright along the X axis then bolt through that plate into the X axis box section.
ID:	13414   Click image for larger version.
  1. Design of small router (700x900) for aluminium
    By Edward in forum Gantry/Router Machines & Building
    Last Post: 16-12-2017, 07:34 PM
  2. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  3. BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
  4. CNC Frame Design Help
    By zhenning in forum Gantry/Router Machines & Building
    Last Post: 26-12-2015, 05:44 PM
  5. BUILD LOG: Steel frame cnc router design/build
