12-10-2015 #10
80 amps seems ok from my experience (a few 10s of 2.5mm and another so many 3.2mm). If between rods you cannot get it to arc, try breaking the flux around the electrode by hand. Careful, it is hot.
It really makes a difference when you have very clean metal both on the hot side as well as where you apply your grounding clamp. Also try to minimise the distance between the two.
Regards
Georgehttps://emvioeng.com
Design of small router (700x900) for aluminium
By Edward in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-12-2017, 07:34 PM -
BUILD LOG: New Build, Aluminium Frame Router/Mill
By Davek0974 in forum DIY Router Build LogsReplies: 101Last Post: 31-08-2016, 05:28 PM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
CNC Frame Design Help
By zhenning in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 26-12-2015, 05:44 PM -
By CraftyGeek in forum DIY Router Build LogsReplies: 110Last Post: 06-05-2015, 10:00 PM
