    Let me just say that unless you intend to move this machine about often then I wouldn't use any connectors. Wire direct from motors to control box to lessen any potential for poor connections and places for bad joints. These type of connectors are one of the prime trouble areas after newness as worn off and cables weight starts putting stress on connectors and pins. They where never designed or intended to be left permanently connected and are meant for short term quick release and connection for the music industry.
    Have you bought the Zapp Kit yet.?
    I built my machine over 2 yrs ago .. been running 24/7/364 since then (ok , maybe 20 hrs a day :) ) ... the cable I used was salvaged hover mower cable 2 core ... two runs per motor ... connected with chocolate block type connectors .. have had no problems what so ever :)
    this is what I started with .. skip dive build :)
    this is the running machine
    absloutely no problems what so ever with wiring connections :)
    Hi irving2008
    Thanks for the post on this. I have used 2.5mm2 4-core SY cable for connecting up my 2.2kw spindle to the VFD. Got an offcut from Premier Cables really cheaply so I will use them as my first port of call. They sell to large users and they said it's good for them to sell off the offcuts so it reduces the stock taking efforts!
    - Mike
    Hey guys, great thread.... I'm now in the position to dismantle the temporary wiring and hard wire everything up. My question is, am I right in say that this is the correct wire to purchase?
    http://pages.ebay.com/link/?nav=item...235457&alt=web
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by D-man View Post
    That wire will be fine but it is too expensive If you search for it you can buy it for about 70p here is a link http://quickbit.co.uk/Cable/CY-Cable...-0-75mm-4-core but this is not the best cable as Dean will point out when he sees this but I just can't find the link for the better quality cable at this time. I will have another look tomorrow
    This is the correct link http://www.csecables.com/acatalog/CY-Cable-4-Core.html ...Clive
  5. #15
    is this the site clive S ?
  6. The Following User Says Thank You to T0rnado69 For This Useful Post:
  7. #16
    Quote Originally Posted by T0rnado69 View Post
    Yes that's the site and yes it's better than the Quickbit stuff.
  9. #17
    Really, i thought it was cheap.... maybe because everything else was so expensive haha
    Cheers guys
  10. #18
    OK guys sorry maybe a silly question but what wirethickness do i need? im using Nema 34 all round apart from the Z
  11. #19
    Glad you got sorted. I have been beaten to it by the night owls or (elves) I have added the link to my post as well. ..Clive
  12. #20
    In that case I would use 1.5mm but do you really need nema 34 motors if so is your power supply big enough? ..Clive
  1. CY cable terminals
    By kingcreaky in forum Marketplace Discussion
    Last Post: 26-03-2014, 08:24 AM
  2. Cable Size ?
    Last Post: 09-05-2013, 02:55 PM
  3. FOR SALE: Cable Glands...
    Last Post: 07-02-2011, 07:33 PM
  4. 30 gauge solid core insulated wire
    By Wobblybootie in forum General Discussion
    Last Post: 23-06-2010, 10:17 PM
