Yeah its the 2.2Kw might aswell bulk it up incase anything changes.
12-10-2014 #2
The trouble with 2.5mm is the connecting in to the plug on the spindle and 1.5mm will carry in the region of 18A which is more than enough. Good luck with the build. ..Clive
12-10-2014 #3
Crap i forgot abut that, thanks for the heads up
12-10-2014 #4
I'm with Clive 1.5mm is fine for spindle and much easier as you can use same cable used on motors even thou only 3 wires are used. Can use 4th wire for an earth if you like but personally I don't bother as never needed to.!
12-10-2014 #5
Ive just ammended my order, thanks Jazz. Glad you replied actually i was looking for the review i think you done on the Leadshine motors, i cant remember if you said these were the way to go or not
12-10-2014 #6
Yes they are great but they are expensive so it gets a close call between them and Servo's so do some shopping around if your thinking to use them.
Only thing they have in favor over Servo's IMO is that they are easy to use and setup with no messing around tuning drives etc.
Servo's will be better if you want higher feeds and torque.
That said if you use Normal steppers tuned correctly and running on good drives then you won't have any issues. Will say thou D-Man if your using 34 motors you want High powered AC voltage drives to get the best from them.! They cost more but also make build control box easier as you don't need a PSU for the drives so don't cost that much more in end.
12-10-2014 #7
Without hijacking this thread i will leave it at that. if you dont mind could i pick your brains at some point soon about these?
CY cable terminals
By kingcreaky in forum Marketplace DiscussionReplies: 15Last Post: 26-03-2014, 08:24 AM -
Cable Size ?
By manofgresley in forum General ElectronicsReplies: 1Last Post: 09-05-2013, 02:55 PM -
FOR SALE: Cable Glands...
By Jimmybristol in forum Items For SaleReplies: 0Last Post: 07-02-2011, 07:33 PM -
30 gauge solid core insulated wire
By Wobblybootie in forum General DiscussionReplies: 8Last Post: 23-06-2010, 10:17 PM
