30-07-2014 #5
Thanks m_c,
I am currently set to 16 on the drivers and it runs fine but will change this to 8 and see how it goes.
The X and Y motors are directly connected but the Z has a toothed belt, It seems to be a 1:1 ration so should be fine. I think i need to measure the pitch of the screws then I can calculate the steps as you described.
The sensors are the 3 wire type and are 10-36vdc so I will get one hooked up to some power and see what the output wire does when it reaches home.
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
bit of advice needed for first mill
By jmac80 in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 06-04-2014, 10:59 PM -
Boxford 125 CNC retrofit advice
By pneanvil in forum Boxford LathesReplies: 4Last Post: 05-12-2012, 11:47 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
