    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    If you get enough speed at 16 microsteps, then there's not really any need to change it. One thing to consider, is microsteps should never be relied on for accuracy, as the stepper position can only be guaranteed to the nearest step. While microstepping, both coils are proportionally energised, with the rotor essentially held between two magnetic fields, so can spring/float (there probably is a better word, but I'm tired!) depending on load.
    Sensers will most likely be NPN with an open collector. Are there any numbers on them?
    If there is, try googling it to see if there are any datasheets for them, which will confirm what they are.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #2
    m100's Avatar
    Lives in Yorkshire, United Kingdom. Last Activity: 15-06-2023 Has been a member for 9-10 years. Has a total post count of 10.
    This post mentions a wiring diagram for the Boxford 190. No reponse to a PM and the user hasn't posted for quite a while.
    Interested if someone can supply a wiring diagram to aid conversion of my 190 (Lenze controller type)
    Thanks m_c
    All the explanation was awesome :)
  1. Advice needed on Amadeal
    By croy in forum General Discussion
    Last Post: 21-08-2015, 01:28 PM
  2. bit of advice needed for first mill
    By jmac80 in forum Milling Machines, Builds & Conversions
    Last Post: 06-04-2014, 10:59 PM
  3. Boxford 125 CNC retrofit advice
    By pneanvil in forum Boxford Lathes
    Last Post: 05-12-2012, 11:47 PM
  4. Advice needed for Z Design
    By Hobgoblin in forum Linear & Rotary Motion
    Last Post: 10-09-2012, 09:18 PM
  5. SPG X3 CNC Mill, advice needed please
    By shaggyhawkings in forum Milling Machines, Builds & Conversions
    Last Post: 07-01-2010, 11:00 PM
