Take a look below.
first draw a line longer than you need so you have overcut of the part, then draw a semi circle like the one in red in your software look for extrude, pick the line as your length of cut, then pick the semi C as your profile and merge them together, you need to orientate your part or the drawing to cross your part using the top face of the part as the XYZ =0 you end up with a semi circle cut into the part as shown.
Hope it helps, if not give me the exact sizes of the part you want to cross and the size of the semi circle and I will do you a code to cut.
Phill
