Thread: Mist lubrication system
Just a suggestion, i was toying with the idea of getting one for my lathe.
19-08-2014 #2
Bumping this to see if anyone can help, advise or has one to sell . . . . .
I have imminent work that could do with me being able to slice aluminium.
19-08-2014 #3
Hi Buddy
Have you considered making one ?. I was looking @ one last week(had it bookmarked on another PC that i only use infrequently) and it uses a water filter housing identical to one that i have just bought off Amazon for GBP15.
Bowl is filled with coolant, regulator controls inlet pressure to the bowl. outlet is 3/4 BSP Female, has an adaptor with two small bore tubes brazed in it. one just takes air from the housing the other has a small tube going to the bottom of the filter bowl to pick up the coolant. two tubes from the adaptor go to a mixing head were you can control quantity of air & coolant.
Mike
Gerber system 48
By martin54 in forum Milling Machines, Builds & ConversionsReplies: 67Last Post: 13-09-2013, 12:35 PM -
My Coolant System
By Tenson in forum Swarf & Chip ManagementReplies: 6Last Post: 08-04-2013, 01:59 PM -
Milling machine -maintenance? (oil, lubrication, specific questions)
By diy-john in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 24-02-2013, 09:03 PM -
Ballnut Lubrication / Grease
By Mad Professor in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 18-07-2012, 08:08 PM -
Lubrication (OOooeerr missus)
By Smiler in forum Linear & Rotary MotionReplies: 3Last Post: 14-10-2008, 07:56 PM
