    Bumping this to see if anyone can help, advise or has one to sell . . . . .
    I have imminent work that could do with me being able to slice aluminium.
    Hi Buddy
    Have you considered making one ?. I was looking @ one last week(had it bookmarked on another PC that i only use infrequently) and it uses a water filter housing identical to one that i have just bought off Amazon for GBP15.
    Bowl is filled with coolant, regulator controls inlet pressure to the bowl. outlet is 3/4 BSP Female, has an adaptor with two small bore tubes brazed in it. one just takes air from the housing the other has a small tube going to the bottom of the filter bowl to pick up the coolant. two tubes from the adaptor go to a mixing head were you can control quantity of air & coolant.
    Mike
  1. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 12:35 PM
  2. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
  3. Milling machine -maintenance? (oil, lubrication, specific questions)
    By diy-john in forum Milling Machines, Builds & Conversions
    Last Post: 24-02-2013, 09:03 PM
  4. Ballnut Lubrication / Grease
    By Mad Professor in forum Lead Screws, Nuts & Supports
    Last Post: 18-07-2012, 08:08 PM
  5. Lubrication (OOooeerr missus)
    By Smiler in forum Linear & Rotary Motion
    Last Post: 14-10-2008, 07:56 PM
