    try cncdirect.co.za. his thc works very well for me
    Thanks, just emailed
    them
    I have 4 of Proma THC and been using them for over 2 months so here is where i am at:
    3mm mild steel light bent at 2-3 cm per feet i can cut at 5500mm/min at 60A all day long, mostly use it at 3000-3600mm/min at 30A so i do not bother to be near the machine at all
    2mm mild steel cut mostly @4200mm/min @30A
    Back to your problem: you did not mention the delay--> lower it on the THC so you get faster response from it, and if this does not help, you might need to change the computer or do a fresh install.
    B.T.W i use linux exlusively but i had a winXP/Mach3 setup for a client that does production work with it on a 3.5mX2m work envelope with a Hypertherm MAX100.
    Regards,
    Tom
  4. The Following User Says Thank You to tommylight For This Useful Post:
  5. #4
    This issue was resolved by fitting an MP3000-DTHCII from CandCNC, this unit can control the z axis very fast which is just what was needed for my finecut consumables that like to run at only 0.75mm cut height.
    It's working very well now.
  1. Replies: 8
    Last Post: 01-02-2014, 09:33 AM
  2. minor issue with latest posts board
    By wilfy in forum General Discussion
    Last Post: 10-01-2013, 12:50 AM
  3. BOBCAD V24, Selecting issue on boundry & geomatry
    By craigrobbo in forum BobCAD-CAM
    Last Post: 14-05-2012, 02:56 PM
  4. Replies: 2
    Last Post: 21-04-2010, 09:50 PM
  5. Fake ebay emails: New issue
    By Lee Roberts in forum Marketplace Discussion
    Last Post: 18-07-2009, 04:01 PM
