    I have bought one of these (ebay item-251214397202) 0.56" Digital Voltmeter Green LED Panel 3/2-Wires DC 0-100V 4-30V Power Monitor. I want to read the voltage of a battery and a solar panel fitted to my caravan. What switch do i need and how would i wire this circuit please.
    Lives in Marple Stockport, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by deannos View Post
    Not sure what you mean by "what switch" but these little meters are quite good for the price. Just connect the red and yellow wire to a + 12volt and the black to the -ve and it will read the voltage of the battery. If you want to read above about 30V then you have to connect the red wire to a source below 30V and the yellow wire to what you want to measure up to 100V. The -ve has to be to be the same for both the supply and the higher voltage you want to measure.
    It would of course be prudent to put a fuse in line to protect the cables ..Clive
    I wish to read either the battery voltage or the solar panel voltage separately, so i thought i would a switch of some sort
    Well in that case you just need a change over switch. Connect the yellow wire to the common and the battery +ve to one of the other contacts and the solar to the other contact. See thishttps://learn.sparkfun.com/tutorials...pen-and-closed you can get a small switch for Maplin ..Clive
    Ok, thanks for your help. So i need a SPDT and switch the common, is that correct
    Yes in this case the common goes to the meter (yellow wire) but the red wire will have to be energised from the battery because the solar panel may not be providing enough Voltage to drive the meter. The -ve on the solar panel will have to be connected to the battery -ve hope this helps you could of course put 2 meters on the system ..Clive
    I did buy 2, be silly not to at that price
    I used 4 on my control box all different colours vey pretty ..Clive
  1. Mach 3 control panel help
    By IanParkin in forum Artsoft Mach (3 & 4)
    Last Post: 05-09-2014, 04:05 PM
  2. Control Panel Guidance
    By GTJim in forum General Electronics
    Last Post: 03-09-2013, 08:42 PM
  3. solar tracking
    By luke11cnc in forum Electronic Project Building
    Last Post: 27-04-2013, 09:47 AM
  4. Small panel for my CNC
    By jcb121 in forum Gantry/Router Machines & Building
    Last Post: 19-02-2012, 12:21 PM
  5. Panel Mount Voltage Regulator / Knob
    Last Post: 29-11-2008, 01:23 AM
