01-08-2014 #1
I have bought one of these (ebay item-251214397202) 0.56" Digital Voltmeter Green LED Panel 3/2-Wires DC 0-100V 4-30V Power Monitor. I want to read the voltage of a battery and a solar panel fitted to my caravan. What switch do i need and how would i wire this circuit please.
01-08-2014 #2
Not sure what you mean by "what switch" but these little meters are quite good for the price. Just connect the red and yellow wire to a + 12volt and the black to the -ve and it will read the voltage of the battery. If you want to read above about 30V then you have to connect the red wire to a source below 30V and the yellow wire to what you want to measure up to 100V. The -ve has to be to be the same for both the supply and the higher voltage you want to measure.
It would of course be prudent to put a fuse in line to protect the cables ..CliveLast edited by Clive S; 01-08-2014 at 06:57 PM.
01-08-2014 #3
01-08-2014 #4
Well in that case you just need a change over switch. Connect the yellow wire to the common and the battery +ve to one of the other contacts and the solar to the other contact. See thishttps://learn.sparkfun.com/tutorials...pen-and-closed you can get a small switch for Maplin ..Clive
01-08-2014 #5
01-08-2014 #6
Yes in this case the common goes to the meter (yellow wire) but the red wire will have to be energised from the battery because the solar panel may not be providing enough Voltage to drive the meter. The -ve on the solar panel will have to be connected to the battery -ve hope this helps you could of course put 2 meters on the system ..Clive
01-08-2014 #7
01-08-2014 #8
I used 4 on my control box all different colours vey pretty
Mach 3 control panel help
By IanParkin in forum Artsoft Mach (3 & 4)Replies: 19Last Post: 05-09-2014, 04:05 PM -
Control Panel Guidance
By GTJim in forum General ElectronicsReplies: 2Last Post: 03-09-2013, 08:42 PM -
solar tracking
By luke11cnc in forum Electronic Project BuildingReplies: 2Last Post: 27-04-2013, 09:47 AM -
Small panel for my CNC
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 19-02-2012, 12:21 PM -
Panel Mount Voltage Regulator / Knob
By Lee Roberts in forum General ElectronicsReplies: 21Last Post: 29-11-2008, 01:23 AM
