Thread: CNC ELECTRONICS Power Supply
04-08-2014 #11
Wait a minute
No offence but your design will fly to pieces on the first error when something hits something. By the look of it you can expect speeds in the range of 10 IPM with depth of cut no more than 1mm.
Lets start from the beginning.
So lets start from scratch with the help.
What is your budget? What you expect to do exactly with the machine?
04-08-2014 #12
I should explain that this is a project for my A2 at college. I except somethings not to work too well as this is just a prototype . I wanted to cut at least mdf, plastic and some 3d foam routing. The concept is based on an exciting machine that appears to work ok. The post here really is to find the correct electronics so that they are transferable to my final machine. The idea is to make a basic machine and then use it to cut the panels out for the end product that would be stronger and be able to withstand harsher loads. Also the photo does not show the whole structure behind the bridge, which is quite strong. My budget for electronics and drive mechs is around £600-700.
04-08-2014 #13
OK, , i thought it was something like that.
Nevertheless you can reinforce the gantry sides, just do a search for MDF cnc and you can get better idea how to reinforce things with minimum cost. And dont forget to paint it.
Now ball screw is one thing and lead screw is another thing, not the same as you call them. You want ball screw, given the current prices of chinese ball screws..
Having in mind your budget, the buy from China directly. the savings will be considerable. AM882 is protected against all - improper polarity of the power supply, so just be carefull and there will be no problem. Will pass you with PM from where i buy stuff. Not that there is a secret - BST automation, many buy from him. This would be cheaper than LMB and any other,+ he is a very reliable seller. He has all you need or will source it very fast.
Hope that helps.
PCPPS V3 Power Supply?
By birchy in forum General ElectronicsReplies: 4Last Post: 10-12-2012, 04:21 PM -
ebay power supply
By irving2008 in forum General ElectronicsReplies: 91Last Post: 29-04-2012, 06:28 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
