Thread: Sieg SX2P mill received
I received the exact same this friday. Great machine but i was using a face mill and the gib plate on the XY same loose and the whole table moved then you turned the handle. I had to tighten them up and it did the very same thing again.
One other thing is when you use the fine adjustment on the Z axis it doesn't move down the amount it says. When you set an amount and then move the drilling handle it drops down like 2-3 mm!!!!!!!!!!!!!! In not sure what to do about this !!
Help, I plan on stripping the machine down tomorrow to and clean it all and Lap the slide ways in. Locktight the gib screw in the correct position.
24-08-2014 #2
yep I have the same bother on the z of my new sx3 it seems to stick then drop a couple of mm, and so on as your lowering it,
ive not tried to address it yet,i don't think there set up right out of the box but something you have to do your self...im seriously thinking of fitting some hiwin rail to my column.Last edited by dazza; 24-08-2014 at 09:37 PM.
sieg kx3 cnc mill
By DGH in forum Sieg Milling MachinesReplies: 15Last Post: 08-10-2019, 08:19 AM -
FOR SALE: Sieg x3
By andris in forum Items For SaleReplies: 4Last Post: 25-02-2014, 06:32 PM -
Number plate dies and a Sieg KX3 CNC Hobby Mill
By p4tvw in forum Milling Machines, Builds & ConversionsReplies: 5Last Post: 14-04-2010, 04:51 PM -
Information retention requirements for ISP's, every e-mail sent or received in the UK
By Lee Roberts in forum General ComputingReplies: 1Last Post: 23-02-2009, 09:57 PM
