    looking around on the net it seams like the same design or model is used world wide and looks like you can even buy a cnc conversion. There seams to be a good number of vid of it cutting aluminium so unless any one has any other suggestions i may go take a look at the use one and possibly give it a go.
    I would thoroughly recommend you have a look at the Seig offerings from Arc Euro. They can set the machine up for you and it would seem to be well worth while. I have a Clarke CMD300 and Yes, it is a toy, but I have played with it a lot.
    http://www.arceurotrade.co.uk/Catalo...lling-Machines
    well i went and took a look and ended up walking away with it. it not great by any means but if i can drill holes accurately and do the odd slot or pocket it should be enough for what i need at the moment and to mean i dont have to take things else were to have small jobs done. I paid £325 and it came with the milling chuck which is a extra £120 a fixing set which is another £70, a small vice clamp and a few end mill bits so not to bad. I think the one mod i would like to do though would be put a belt drive conversion on the spindle and the gears are a little shonky and then maybe once my big machine is up and going maybe a ball screw and cnc conversion and maybe even some linear rails but thats a long way off. Ether way i will be putting it to test tomorrow.
  1. WANTED: Wanted - small bench cnc mill
    By camhguh in forum Items Wanted
    Last Post: 25-01-2012, 11:22 AM
  2. 1st CNC Mill for small machine shop
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:47 PM
  3. WANTED: Small CNC Drill/Mill
    By Mad Professor in forum Items Wanted
    Last Post: 03-09-2010, 01:28 PM
  4. Best software set for a small cnc mill ?
    By NICKMODELMAKER in forum Computer Software
    Last Post: 12-06-2010, 11:20 PM
  5. Bench Top Mill
    By Wobblybootie in forum Milling Machines, Builds & Conversions
    Last Post: 04-06-2010, 06:57 AM
