Thread: Motor and Drive selection
Yes you will but you could use one motor and drive the other screw via a long timing belt.
I don't see why not, each axis is it's own little 'system', you just need to make sure the parameters are correct in your software so that when told to move 200mm, it actually moves 200mm.
Obviously choice depends upon your particular application but most people use 3.1Nm motors. My machine cuts wood at 900 x 600 and I used these ones; http://www.cnc4you.co.uk/index.php?r...ory&path=83_85 They work well.
This is a useful read; https://www.geckodrive.com/gecko/ima...cs%20Guide.pdf
Most people use the bipolar parallel connection.
Just what it says, it breaks out the wiring from your machine to the controlling PC. If you look at most boards they have a PC parallel port and several rows of terminals. The computer connects to the parallel port and your drivers, limit switches, etc. connect to the terminals. Instead of using a PC parallel port, as these have been phased out now, you can use an interface board such as a Smooth Stepper that connects via USB or Ethernet.
SketchUcam produces G code from drawings, Mach3 enable a computer to control your machine hardware, G code is the instructions that Mach3 uses to move the machine in such a way that your drawing is realised in wood etc. So SketchUcam does not bypass Mach3, you need three pieces of software basically, CAD, CAM, controlling software e.g. Mach3.
For manual control you can use a device like this; http://www.ebay.co.uk/itm/MACH3-CNC-...item1c33379d0a
or there are more expensive ones and some people make their own from X Box controllers and the like.
Finally I would say that if you build a 'budget' machine you will get 'budget' results. From what you have described I would have used none of that stuff, I know there are videos showing MDF made routers and they seem to work but I think you will be disappointed with the results. Have a look at these build threads to get an idea of what you should be thinking about.
http://www.mycncuk.com/forums/253-DI...ter-Build-LogsLast edited by EddyCurrent; 14-08-2014 at 11:46 AM.
14-08-2014 #2
14-08-2014 #3
Thank you for the comments, some helpful stuff there.
I have very limited space in my workshop and this machine has got to earn it's place. There are many ways to machine a bit of Wood and I may find out that it is just not worth spending hours in CAD to achieve results I could do in minutes with hand or power tools.
I like the fine detail and repeatability that CNC should offer and I do love building machines (6 Bandsaws so far.. some out of MDF.. and very accurate cuts too..). I am quite happy to go cheap to understand and learn what I am building and then do it again with better components at a later time.
My Tubular steel frame is very adjustable and rigid. I have been reading a lot of the build logs on this and other sites including a lot of Youtube Vids but I do realise my limitations and understanding Electronics is my biggest problem area. I am hoping to just take recommendations from other builders as to what components would best suit my project and personal experiences with, say.. The German Longs88 stuff..
Thank you Clive, I was being generic.. I didn't/dont know how connected the different drives were to each other and if they all had to have a similar ratio..
I am still interested in anyone's opinion of this xPRO http://www.spark-concepts.com/cnc-xpro-controller/
Thanks all
CNC3040Z Motor and Spindle Selection.
By vksingh in forum Chinese MachinesReplies: 13Last Post: 25-06-2014, 04:50 PM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
stepper motor selection for my diy cnc machine
By crossleymarko in forum Stepper & Servo MotorsReplies: 1Last Post: 08-04-2012, 03:19 AM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM -
Who is the best online ball screw supplier and stepper motor selection
By NICKMODELMAKER in forum General DiscussionReplies: 9Last Post: 14-03-2010, 04:04 AM
