Thread: My Machine
    Another creep.............:wave:
    Creeping isn't such a bad thing John, It worked for me!! Thanks again for the bit you made!!!
    I'm interested in this whole business with the laser. I had no idea DVD diodes were powerful enough to do anything... other than read dvds... and make home made laser pointers.
    Do you think you could post a little info on how you did it?
    Cheers,
    Dave.
    Well what do you want to know about DVD laser burning?
    You could just buy a 300mw DVD diode in a 12x30 mm housing with lens and driver board off Ebay for about £30, Seller I think is in South Korea but had a good track record with UK customers.
    I made a mount to hold the diode where my spindle would usually go, The driver board I used needed a 6v Regulated supply so I just gave it 6v via a regulator switched via a Solid state relay driven directly by the parallel port.
    I then wrote a simple script that swapped out Z moves in the G Code created by Cad software for M codes to turn laser on and off, The etching of a baby on some wood was done with a 180mw 635nm DVD laser diode.
    Focusing the laser takes a little trial and error, But I got a spot size down to 0.07mm, Even 180mw at a spot size that small is a fair amount of energy.
    Please feel free to ask me any questions as I know I ramble and talk shit sometimes.
    Michael.
    Quote Originally Posted by Kip View Post
    Please continue to talk shit...I'm hooked ;)
    I second that :)
    John S -
  1. Replies: 0
