Thread: My Machine
01-06-2009 #30
Okay.......
Power - The one I used was 180mw 635nm (visable red)
Where to get/PSU & focusing all here http://cgi.ebay.co.uk/300mW-650nm-Re...3A1%7C294%3A50
This includes everything you need, really easy. Comes with lens & body which is 12mm od so you'll need to fashion a clamp for that. The lens supplied is plastic however so was the one I used.
To drive it, simply give it 6 - 20v when you want it to fire. I would reccomend either a transistor or solid state relay to turn it off / on as switching speeds could get to high for a mechanical relay.
Focusing is easily adjusted by rotating the lens at the end of the unit.
At 180mw - 300mw you will only be cutting foams up to a few mm's and vinyl / stickey back plastic.
for engraving, Pretty much anything organic eg; leather, Wood etc. Also most plastics but results will vary depending on the colour of the material, A red laser will hardly leave a witness mark on red plastic and would struggle to set fire to bright white paper. However if was a slightly darker colour paper would ignite almost instantly.
John S. When ever you like mate!!!!
Michael Duffin.
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM
