Thread: Feedback on 1.0 design
Round rail will be fine for wood and light work, though like G suggests if you want depth of cut, faster machine speeds and a decent finish in metals then spend more going for linear guideway...as you know.
Would love to watch the build log for this if you do go down the poxy road.
.MeLee
16-08-2014 #2
Interesting, and thanks for the feedback. Much appreciated.
So, is the supported round rail really that loose? I'd like to say that I'm okay with babying the MRR, but I know that will grow old sooner rather then later so I am certainly looking into profile rail.
I basically scaled down the design idea from a Mazak that I run pretty often, and love. However after a few hours of looking more into this I'm beginning to wonder the following scenario:
Build a "cheap" heavy duty router in the style listed above (with round rail) for the decorative work that doesn't require anything tighter then 0.3 - 0.4 mm or so. This will allow me to expand the X & Y and reduce the Z and worry a bit less about rigidity...
meanwhile...
Build a stout metal mill. Classic vertical mill, stout "L" shaped base with minimal throat and reasonable X & Z travels. Most of the metal workpieces in mind require no more then a 100 x 100 x 100 (mm) cutting envelope. This, with some more thoughtful table design will allow me to "justify" the profile rail expense, as most other components will be the same or less actually. I'll basically save this for the aluminum, brass, and the super rare carbon steel parts.
Granted it is at least a good excuse to have two machine tool projects. The wife will understand I'm sure
16-08-2014 #3
You are nearly there but you are misunderstanding the fixed gantry advantage. The supported rail mounts to the table and the bearing blocks go close under the tool tip. Turn the rails over and get the support where the cutting happens, where you need it, lose the overhang.
16-08-2014 #4
nice design njcook.
like others said profile rails the way to go.
and if you haven't already,make provisions for splash guards/coolant return during the build keeping the screw and rail free of it.Last edited by dazza; 16-08-2014 at 06:21 PM. Reason: didnt want to trash anothers thread
Feedback poll - which age group are you?
By mocha in forum General DiscussionReplies: 66Last Post: 22-02-2026, 10:09 AM -
Doris CNC - early feedback appreciated
By woodspiral in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 08-06-2014, 10:57 AM -
Feedback
By Jester in forum Stepper & Servo MotorsReplies: 1Last Post: 02-02-2014, 03:49 PM -
Feedback Poll - Do you like reciving the Newsletter ?
By Lee Roberts in forum General DiscussionReplies: 8Last Post: 24-12-2012, 06:34 PM -
Position feedback
By D.C. in forum Electronic Project BuildingReplies: 4Last Post: 17-10-2012, 11:30 AM
