  1. #9
    You mentioned a larger screw being needed, I guess that depends on feed rate as well.
    The other structural option is single screw with a long beam.
    Can someone help out with rough estimate of the cost comparison. I need the cost of a twin ballscrew set-up versus a single screw for 1800mm travel. That includes the screw assembly, and the motors and motor drives. I realise there's a lot of calcs in that, and it will take me some time to track them all down on the forum.
    Here's the single screw layout, I'm not sure I even like it. If the beam is going to need to be deeper then that's already counteracting the single screw cost saving.
    If someone was to say forget single screw, you need 2 screws, I wouldn't be upset.
  1. Wood cnc router for hobbyist
    By nerostjames in forum Machine Discussion
    Last Post: 01-01-2018, 09:28 PM
  2. wood sign cut with cnc router
    By jonm in forum Woodworking Project Showcase
    Last Post: 09-06-2014, 08:05 PM
  3. BUILD LOG: Design stage of 4030(ish) for wood and plastic
    By andy586 in forum DIY Router Build Logs
    Last Post: 14-11-2013, 10:07 PM
  4. BUILD LOG: Wood Router
    By Buba b in forum DIY Router Build Logs
    Last Post: 03-10-2012, 09:49 AM
