Hi Jazzcnc
It has an emach badge and serial number on the side, so I naturally assume it was one of theirs. 2006 model, so perhaps made before the rot set in at the factory.
The current owner is the son of the (Late) granddad in a family "Oop Norf" in Halifax, the old boy bought it in 2007, had good service from emach at the time and used it very little. Allegedly it's had very little use overall and comes with a small selection of tooling.
I'll know more after Sunday when I collect it and get it back for a proper look-see, although I'll be unable to actually produce anything just yet as I'm still sorting somewhere to put it and use properly.
Having fun with the designing using V Carve trial, quite intuitive. I'm hoping it's post processor is simply G code as well.
If you can't fix it with a hammer you've got an electrical problem !
19-08-2014 #2
Ye didn't mean it wasn't from E-mach but I'm confident they just badged up a Chinese import.
The post processing is done in CAM not at the controller IE: V carve and output in the format your controller understands. The DSP is the controller and will more than likely just take any vanilla G-code file so use say Mach3 or linux Cnc post processor in V carve. I don't use V carve so don't know the Post's it comes with as standard but I'd be amazed if it didn't have Mach3 post or some generic post.
"Oop" North Halifax is just stone throw away for me . . . Lol
19-08-2014 #3If you can't fix it with a hammer you've got an electrical problem !
NEW MEMBER: Hello from Hope, Arkansas --- USA
By Skeeter_MTI in forum New Member IntroductionsReplies: 1Last Post: 11-01-2011, 03:49 PM -
NEW MEMBER: Hi. I'm new to CNC with a story of hope!
By cuttingaxe in forum New Member IntroductionsReplies: 1Last Post: 17-08-2009, 03:59 PM -
Hope Irving is ok
By Smiler in forum General DiscussionReplies: 3Last Post: 28-11-2008, 10:43 PM
