    Quote Originally Posted by GEOFFREY View Post
    Hi, I do quite a lot of routing with 3.2 and 6.3mm HDF/MDF. I mainly use 2mm PCB endmills and run the spindle at 2400+ rpm and a feed of about 2M/min. I do sometimes (if in a hurry) run at 3or4m/min, but worry a bit about tool breakage. at 2M/min the tools last for ages.
    That's a very slow speed, "2400+", what depth of cut do you use ?
    I think that might be a typo for 24,000 rpm. ..Clive
    Yes, thanks Clive, of course I did mean 24000rpm. the slowest my spindle will run is 1500rpm.
    I always cut HDF/MDF in a single pass, but only cut up to 9.2mm. For the 9.2mm I use a 3.172 cutter. G.
  1. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  2. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  3. Cutting Ply/MDF
    By Leadhead in forum Wood Finishing Tips & Tricks
    Last Post: 02-10-2013, 01:59 PM
  4. Cutting HTD pulley(s)
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 11-12-2012, 07:19 PM
  5. Gear cutting
    By John S in forum CAD & CAM Software
    Last Post: 03-10-2010, 07:55 PM
