Thread: Router build
    so onto my next build ....
    my rails have arrived , yay so am just waiting for the motors and drivers
    still have to select a spindle, but im quite set on a chinese 3kw water cooled , i had a 1.5kw on my old machine and was quite impressed with it even though i blew the VFD up :S oops
    cutting size is 2400x1200x200 so that a std sheet will fit in the machine ..
    25mm rails on X Y and Z ..
    Z will have a 20mm ballscrew X & Y will be on mod 1.5 rack and pinion
    10:1 step down boxes on X and Y with a 26t pinion , Z will either be belt with 1:1 pulley, or direct drive with coupling
    rapids will be around 15m/m , will probably speed this up in due time
    the frame is quite conservative i think ... and now i dont know if i want to go bigger rectangle section or just stick with the 76mm square
    all steel build , gantry sides are 6mm steel plate laser cut , two 76mm box sections for the gantry
    Z plates are 10mm with another 10mm to space out for the bearing blocks
    epoxy self leveling construction method will be used
    where does it stop :D
    i will mainly be cutting wood and plastics (corian - acrylic) so i dont need a terribly stiff machine ... for now ... my next build after this will be for aluminum
  2. How Not To Build A Router
    By Clive S in forum Gantry/Router Machines & Building
    Last Post: 17-11-2013, 10:09 AM
  4. BUILD LOG: My Router Build!
    By andy0202 in forum DIY Router Build Logs
    Last Post: 31-01-2013, 08:51 AM
  5. BUILD LOG: A3 Router Build
