Thread: help with problem please
23-08-2014 #2
no loose wires Jazz, it's the same 2 axis all the time, machine jogs about great when first started then you go to jog either the y or z axis & the motors don't turn but the dro on mach3 is moving
23-08-2014 #3
23-08-2014 #4
As it got a shity cheap chinese BOB.?
23-08-2014 #5
Yer & cheap Chinese drivers as well, he bought 3 drivers & a bob, wired it all up & the x axis driver blew up, seller told him to try again & he blew up another driver lol, was asked for pictures to ensure all was wired correctly & after sending the pictures was sent a complete new set of drivers & bob, still no joy so seller sent another bob
24-08-2014 #6
Ok Well sounds like he needs to take the Hint and buy some decent gear.! . . . . . Bet there the TB based drives as well.?
That said Because 2 drives are going off at same time I'd be inclind to think it's the BOB not the drives but swapping the good working axis drive will show up if it's the drive or BOB.?
Not something I'd recommend unless the person is confident with electrics is to by pass the BOB all together and wire direct from the PP pins but this is a risky move and could blow the PP if not done correctly. So only for the competent hacker really.!Last edited by JAZZCNC; 24-08-2014 at 12:57 AM.
24-08-2014 #7
will try switching the axis around to see what happens, could probably use my bob to test the machine if I had to, I know that works fine lol
Eagle CAD problem
By Fivetide in forum CAD & CAM SoftwareReplies: 11Last Post: 06-05-2013, 11:56 PM -
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
NEW MEMBER: New with a threading problem
By GeoffS in forum New Member IntroductionsReplies: 4Last Post: 02-12-2009, 09:23 PM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
