Here you go Eddy just like this. . . .Simplizzz.!
http://www.veneersupplies.com/produc...ping-Jigs.html
24-08-2014 #2
Looking at both bought and home made, I wonder how accurate they are. For example you have a piece of aluminium, say 300mm square, it's even thickness all round, you mount it on the pod, then do an engraving cut at 0.2mm all over the surface, will it work ? Also keep in mind it's no good skimming the surface because then the stock will be of uneven thickness and in some cases this will matter.
One aspect is the gasket, with it being of flexible material it will 'give' due to Z downward pressure.Last edited by EddyCurrent; 24-08-2014 at 08:36 AM.
24-08-2014 #3
Eddy, once sucked down there should be no further "give". The gasket compresses and just forms a seal. However I do not think that PODZ is the answer as I imagine that with profiled alphabet letters nos. etc. it would be very difficult to be able to cut right through without damaging the pod as the items are likely to be quite small. "Tagging" does work very well, and nib/tab/tag removal is very easy. Double sided tape does work ok, but if there are a lot of small components it means a lot of tape to apply and remove. G.
24-08-2014 #4
24-08-2014 #5
Yes agree Geoffrey that's why I said if largish shapes. I built a machine for someone who uses it for letters etc and they use DST but it is a pain to them and a vacuum bed to hold small parts is out the question due to size of setup required as you know.
Tabs are good but again cleanup required so time.!!. . . . . It's a challenge but if was so easy everyone would be at it, which they are starting to be.!. . . Lol
In this case eddy you have them pull down to the POD surface (It's a differant setup to what I posted but same setup as I described with cutting groves and using gasket) and the gasket just forms the seal. The trend setup and the PODZ style of pulling to sealing tape is only any good for wood use really where that level of accurecy isn't required.
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM
