    My mill is about 3 years old and used mainly for making clock parts, the reason for converting to CNC is to speed up the cutting out of clock wheel's and plates and to move away from cutting by hand with a fretsaw.
    I am using the original lead screws but replace the cast iron nuts on the “X”and “Y” axis with Acetal nuts made to the method described by Evan Willams.http://bbs.homeshopmachinist.net/thr...s-the-easy-way.
    The backlash with the new acetal nut for the “X” and “Y” is X =0.08mm and Y=0.05mm, on the “Z” axis I have fitted a gas strut to control the weight of the head which also looks like it is controlling the backlash, but I will see how it works in practice before making any more modification.
    For software I plan to use FreeCad > HeeksCad/Cam > LinuxCNC.
    Next phase will be to buy the stepper motors and controls, which will be in October due to Holidays.
ID:	13178   Click image for larger version.
ID:	13179   Click image for larger version.
ID:	13180   Click image for larger version.
ID:	13181   Click image for larger version.
  1. CONVERSION: Myford VM-B CNC Conversion.
    By John S in forum Conversion Build Logs
    Last Post: 25-03-2014, 10:10 PM
  2. CONVERSION: Sieg X2 CNC Conversion
    By A11an in forum Conversion Build Logs
    Last Post: 16-01-2013, 06:06 PM
  3. CONVERSION: X2 conversion on a budget!
    By craigrobbo in forum Conversion Build Logs
    Last Post: 30-10-2012, 05:00 PM
  4. CONVERSION: Archdale Conversion
    By meyerga00 in forum Conversion Build Logs
    Last Post: 17-06-2012, 09:24 AM
  5. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
