Thread: Pillar drill
    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 09-02-2025 Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    I have used these hundreds of times but never taken any notice of power of the motor.
    For drilling holes up to 10mm dia and 60mm deep on 7075 Aluminium, what would be the average power of the motor ?.
    I have seen an old heavy Silex 150w pillar drill for sale, but Im doubting the power.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
    I use this one, 650W, it drills what you want no bother.
    http://www.axminster.co.uk/jet-jdp-13-pillar-drill
    You do though have to take into account the gearing, if the drill chuck is driven through speed change belts, then at lower speed it will increase the torque.
    Jonathan probably has a spreadsheet for it
  1. metalworking pillar drill experiences
    By routercnc in forum Workshop & Equipment
    Last Post: 19-09-2024, 07:44 PM
  2. Good quality pillar drill?
    By newtoid1986 in forum Machine Discussion
    Last Post: 19-04-2013, 01:40 PM
  3. Pillar Drill Restoration
    By Treemonkey in forum Machine Discussion
    Last Post: 24-03-2013, 07:42 PM
  4. pillar drill?
    By wilfy in forum Machine Discussion
    Last Post: 10-11-2012, 09:18 PM
  5. Dead pillar drill...
    Last Post: 27-10-2008, 03:54 PM
