These are the basic steps to make the VFD work with your spindle:
F0. 0 1: External input signal (0~10V / 0~20mA)
F0. 2 1st part of LED 1:Control by external terminal
F0. 2 3rd part of LED 1: Valid
F0. 2 4th part of LED: Self-startup when power-on 0: Prohibit
F0. 4 Upper freq [F0.3] ~ 1000 Hz 400/ if your spindle is 24000rpm, if not divide RPM/60
Check if these 2 are by default 10: if not set
F0.5 Acc time 10:
F0.6 Dec time 10:
Spindle speed control:
connect from BOB to terminals 10V/+/ and CM/common/
F1. 1 AI input upper volt [F1.0] ~ 10.0V , Leave that to 10 if you board outputs 0-10VDC for spindle control, change to 5 if the board outputs 0-5VDC
F1. 3 Max setting freq 400/if your spindle is 24000rpm
Protection:
connect terminals Ta Tb /NC normally closed/ to the ESTOP circuit, so that if the inverter trips it will stop the machine
When you are finished with all of the above:
F0. 10 Parameter read-in protection 2: Only allow to modify this parameter
How to turn it on off and the speed control:
not all the info is relevant to your case, so remember your settings from above, but read about mach 3 , relay assignment and checking the speeds. You will need a cheap tacho
If you dont have a relay output/alsmost impossible/ , you will need a cheap ??V relay/depends of voltage output of your board/ from ebay.
http://www.cjh.com.au//PWM%20Spindle...ng%20Mach3.pdf
02-02-2015 #2
@ Silyavski, thank you very much for taking the time to go thru my VFD manual to help me. I think I'll get it going now and I will also connect the VFD failure relay to my EStop circuit.
@Neale, Ahh, thx, now that makes a lot more sense to me. I can now see why one would use this. I guess emulating the functionality by using a few relays that drop out on estop would not be impossible but getting the reset functionality to work would be very difficult for me, so it would be a lot easier to just use a component. Had a look on RS-online but new they are expensive so I'll try and find a second hand or discontinued one from a seller thas will to send here. Just wondered why on earth they call some models a PNOZ, do they know what it sounds like when you pronounce it in english :-)
@Eddy, thanks that's a very useful link.
BTW you guys were right, I did a cad layout of my control box this weekend and its MUCH larger than I thought if I follow the component manufacture's guidelines for spacing between parts. I'm going to need a small lotto win to complete this machine if I want a nice PNOZ, a steel enclosure and a CSMIO/IP-M. Scratching around to see if I can't maybe liquidate some other redundant hobby stuff :-)
advise options needed on laser upgrade/add on
By george uk in forum Laser Machines & BuildingReplies: 9Last Post: 19-07-2014, 10:54 PM -
Newbie design need advise
By mogu in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 15-07-2014, 04:52 PM -
Welding Advise Needed - Can this welder cope?
By cncJim in forum Welding, Brazing & EquipmentReplies: 4Last Post: 20-02-2014, 01:25 PM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
Flappy machine - Advise needed please!
By cncJim in forum Machine DiscussionReplies: 22Last Post: 01-11-2013, 03:23 PM
