Quote Originally Posted by mitchejc View Post
@ silyavski
oint 2: The belt length is also bothering me. I really like the way you did yours but I have a bit of a problem because I already have a 350mm long ball skrew for my z and also my steppers which are very long so there's just no way I can do it the same as you did yours. My compromise at this stage is to make the gantry top narrower to move the stepper closer to the ballskrew or go with the long 650mm belt. Which one do you think is the better option? I think my wife will poison me if one more parcel with cnc parts gets delivered here so getting a longer ballskrew is not an option
Then flip the motor. Look at the z i am doing right now.
Note that:
-the plate is reinforced against vibration with the small triangular pieces
-longer towards the front plate - to provide dust protection
-longer towards the back - to mount the cable chain there
Name:	z motor.jpg
ID:	13290Click image for larger version.
Name:	z motor 2.jpg
ID:	13291Click image for larger version.
Name:	z motor 3.jpg
I wish I could hear silyaski machine take an aggressive cut into a piece of alu then maybe I can put my mind at rest about the steel structure resonance :-) Has anybody tried to fill the steel sections of the gantry etc with high density polyurethane foam and would that make any difference with resonance? I'm referring to the two part stuff that can be pored thru relatively small holes and then it foams into a plastic like solid to fill the entire void.
Dont worry about that. It does not vibrate at all. I see your design ok. Not quite the expert though. use common sense and reinforce with 10mm steel rib plates where necessary against bend and twist
Important part of my design are the stair like pieces which reinforce in all directions and don't transmit resonance. To understand better what i am saying, this design is better than just sticking two profiles together.
Split and conquer! That's how you fight resonance.
Soon will make some aluminum pieces for my machine i am building right now, so will show a video about the aluminum, though my friends machine/ the yellow one from the build / has only 0.8kw spindle so it could not be appreciated very much, but there is no resonance, glass like finish.
