21-11-2014 #18
Ok, now its down to bartering. A friend needed some aluminium house numbers urgently and he had something I wanted, so I cut the numbers Wednesday night and swapped this
for this
Great deal, don't you think? :-)
Back to plan A of using I-beam for the gantry sides. The beam I got was a bit higher (254x148) than I hoped for but I'll make it work. I guess for me DIY CNC is more about what I have/can get/can build rather than building the ultimate design from the best choice of material. I also listened to the advice and went with a slightly more practical approach and used 76x76 square tubing, and some 10mm and 5mm plate and also bolt or weld the X sides directly on the base. Gantry weight is +- 60kg excluding Z. I know Y rails top bottom is the better approach but I'm thinking its going to much easier for me to get them parallel and on the same plane if I put it on the front. I'm hoping the laser cutting is not going to be too expensive otherwise I'll have to go for plan B with the gantry. See pics below.
Again please comment if you see any obvious issues.
advise options needed on laser upgrade/add on
By george uk in forum Laser Machines & BuildingReplies: 9Last Post: 19-07-2014, 10:54 PM -
Newbie design need advise
By mogu in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 15-07-2014, 04:52 PM -
Welding Advise Needed - Can this welder cope?
By cncJim in forum Welding, Brazing & EquipmentReplies: 4Last Post: 20-02-2014, 01:25 PM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
Flappy machine - Advise needed please!
By cncJim in forum Machine DiscussionReplies: 22Last Post: 01-11-2013, 03:23 PM
