  1. #29
    Building the x sides with I-Beam and laser cut parts.
    Cutting the i-beam. Thought this was going to be a huge issue because the beam I got is much larger than my cut-off saws capacity but it was done a few minutes later using two cuts and the angle grinder for the remaining bit in the middle.
    I got all the holes lasered way oversize and made alu inserts for them. Just figured its a lot easier to ream alu bushes should I need some adjustment later to align things
    welded in ball skrew mounts
    welded in motor mount
    some test fitting just to see how these parts goes together
    I think using i-beam for the sides were a good plan and really easy to assemble and I can recommend this kind of approach for other newbies.
Name:	20141122_151318 (Small).jpg
ID:	14229   Click image for larger version.
Name:	20141208_164151 (Small).jpg
ID:	14230   Click image for larger version.
Name:	20141122_141805 (Small).jpg
ID:	14228   Click image for larger version.
Name:	20141208_170425 (Small).jpg
ID:	14231   Click image for larger version.
Name:	20141208_200321 (Small).jpg
ID:	14232   Click image for larger version.
Name:	20141209_132503 (1) (Small).jpg
ID:	14233   Click image for larger version.
Name:	20141209_200354 (Small).jpg
ID:	14234   Click image for larger version.
Name:	20141209_200446 (Small).jpg
  1. advise options needed on laser upgrade/add on
    By george uk in forum Laser Machines & Building
    Last Post: 19-07-2014, 10:54 PM
  2. Newbie design need advise
    By mogu in forum Gantry/Router Machines & Building
    Last Post: 15-07-2014, 04:52 PM
  3. Welding Advise Needed - Can this welder cope?
    By cncJim in forum Welding, Brazing & Equipment
    Last Post: 20-02-2014, 01:25 PM
  4. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  5. Flappy machine - Advise needed please!
    By cncJim in forum Machine Discussion
    Last Post: 01-11-2013, 03:23 PM
