Hi Guys,
Does anyone have some nylon sheet for sale please or know where the best place is to get some. Min size 20mm x 300mm x 300mm I made need slightly larger. I just need to finalize a design and want to know where to buy from in advance.
Many thanks
Suesi
25-08-2014 #2
You won't like the price
http://www.directplasticsonline.co.u.../Natural/20mm/
25-08-2014 #3
Hi mekanik
Tar very much for that I have had a look just what I was after as for price nothing is cheap now it seems well nothing I ever seem to go after!
Many thanks
Suesi
25-08-2014 #4
Try ebay as well, just had a look through my records and i purchase a sheet of Delrin 1000 x 200 x 20 for GBP 30.45 with an unrecognized email address so it was probably an ebay seller, you could get lucky.
Mike
25-08-2014 #5
25-08-2014 #6
Hi there,
That is a big help to me so many thanks
Suesi
27-08-2014 #7
Not knowing why you chose Nylon but I would like to suggest an option that I have not seen mentioned on these posts which is.. HPL (High Pressure Laminate) aka Trespa.
It is a dense (usually Black) resin/paper material (think, very thick Formica) which comes in board form (up to 3 x 4m) with thickness's from 6-14mm. You have probably come across it in Public Toilets as the cubicle walling and doors. It is possible to get it on Ebay for between £10-£20 psm second hand. It is also used to clad modern buildings (screening). Generally with a paint finish to both sides.
It is very rigid and machines very well.. (Routers are best) holds thread very well and because it is formed with heat and pressure is much less brittle than cast plastics like acrylic.
I consider it to be a viable alternative to Aluminium for frame building though I think I would get shot down for my impudence from the elders..
Making Aluminum offcuts - what tool?
By lateAtNight in forum Tool & Tooling TechnologyReplies: 15Last Post: 28-07-2012, 02:44 PM -
Delrin & Nylon S & F please
By craigrobbo in forum Machine DiscussionReplies: 2Last Post: 21-07-2012, 12:19 PM -
RFQ: Parts CNC machined from Nylon
By egimson in forum Projects, Jobs & RequestsReplies: 3Last Post: 02-04-2012, 08:40 PM -
WANTED: Roller end caps from pvc or nylon Help!
By stevedunn in forum Items WantedReplies: 10Last Post: 19-09-2011, 10:09 PM
