25-08-2014 #5
No it's the Parallel port that struggles not the electronics. The higher the steps the more pulses required for the same distance hence why the higher the step count the slower the machine can be tuned with the set Kernal speed in Mach3.
Going higher on the steps helps smooth the motors but works the PP harder and this can cause missed steps if it's struggling.
8 is a good setting and I would leave it there.
Regards the drive problems check the STep & Dir connections at the drive giving the trouble this as been a cause of trouble in the past on these machines along with shity wire quality.
Spindle will run for ages 1 hour + without cooling if not under load. I've often cut small jobs without turning my pump on.
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Durability of a 6040 ?
By jimbo_cnc in forum Machine DiscussionReplies: 10Last Post: 11-08-2014, 01:37 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
