I'm not familiar with what the diffferent wires are, but the BOB has a 4pin connector for each axis. 3 of the 4 pins are used and the 4th pin has a loose wire hanging from it. The BOB looks like it has also the option of output via screw terminals, so I could cut the terminal blocks off and use those. But I'm wary of doing that before I hear from the seller, and if I get a replacement BOB Id rather just plug it in.
The wiring all looks pretty nice to me, but I'm not an electrics person. All the sockets into the controller feel like plastic, but they are conductive, I've tested the continuity of the casing.
Just grabbed this pic of my BOB from ebayLast edited by jimbo_cnc; 25-08-2014 at 10:03 PM.
25-08-2014 #2
Ok well I'm not a fan of those silly plugs and I'd wire to the terminals every time but your correct to wait untill seller responds.
That said if the problem moved then it won't be the BOB and chances are it's a drive or wiring to drive.? . . Again I would check the connections at the drives.
26-08-2014 #3
I moved the outputs of the BOB to different drivers. So the problem changing axis shows that the driver is not the problem as the problem follows the BOB output independent of which driver it is wired to.
Here is a boring video of the 2 problems.
https://www.youtube.com/watch?v=IoAGHdbffnQ
26-08-2014 #4
Using the red LED's on the drivers as diagnostics, what happens when everthing is connected apart from all the motors ? i.e. just unplug all the motrs, does the fault still happen ? DO NOT unplug them with power on, it will probably blow the drivers.
26-08-2014 #5
The LEDs behave the same with no motors connected (there was just 1 connected in the video)
26-08-2014 #6
Did you try a different computer ? Is it currently a desktop or laptop ?
26-08-2014 #7
new findings: forget what I thought before about the drivers all being equal.
When I disconnect the inputs and outputs from the non-used drivers (easy with plug in modules :) ) I find that I only get the malfunctions when using driver2, drivers 1 and 3 can't be made to fault by pressing the jogs on the other axes.
I will go run this simple test on the BOB X and Z outputs in a bit (if driver2 doesn't fault on the X or Z axis then the BOB is also involved in the problem).
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Durability of a 6040 ?
By jimbo_cnc in forum Machine DiscussionReplies: 10Last Post: 11-08-2014, 01:37 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
