26-08-2014 #13
new findings: forget what I thought before about the drivers all being equal.
When I disconnect the inputs and outputs from the non-used drivers (easy with plug in modules :) ) I find that I only get the malfunctions when using driver2, drivers 1 and 3 can't be made to fault by pressing the jogs on the other axes.
I will go run this simple test on the BOB X and Z outputs in a bit (if driver2 doesn't fault on the X or Z axis then the BOB is also involved in the problem).
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Durability of a 6040 ?
By jimbo_cnc in forum Machine DiscussionReplies: 10Last Post: 11-08-2014, 01:37 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
