01-10-2014 #31
I took the spindle off the machine and put it in a vice to feel the runout properly. It's weird, it seems to be there at one angle and not another, then it disappears, then it comes back.
I could resist taking it apart, and it was easy. At the collet end a cap is held by four screws. The cap has 6 springs acting on a plate, then some steel shim washers, then a plastic washer and onto the outer housing of a single bearing. The shaft pulls out easily and there is a smaller bearing pushed onto the other end of the shaft.
I don't know about high speed spindles, or any other rotating machinery for that matter, but it seems like a reasonable design.
I'm wondering now if the play I feel is actually play at the other end of the shaft, the other bearing might be a loose fit in it's bore. It certainly didn't give me any trouble sliding the assembly back together but it could be designed with a taper to do that. The play does feel somewhat 'remote' and there are only 2 places it can be.
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Durability of a 6040 ?
By jimbo_cnc in forum Machine DiscussionReplies: 10Last Post: 11-08-2014, 01:37 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
