Thread: Trim/Laminate Router
The short answer is "it depends". Running it on the lower frequency means it will run 20% slower therefore and because V/f ratio has changed from 110/60 to 110/50 current is 20% higher so it will run hotter. Whether that is an issue I can't say because it depends on how its used. Short bursts of use with time to cool down might be a practical solution. An alternative approach is to bring V/f back in line by using a 240/90 step down rather than 240/110. This will bring current back in line but will reduce power by 20% (power = revs x torque, and torque is proportional to current) so you may have to reduce feed rates and/or DOC.
28-08-2014 #2
I was going to say run it on DC thinking it was a single speed universal brush type motor, a commutator is just a rectifier. BUT having looked at the spec. I see it's variable speed so AC only.
Have you contacted Rigid to see if it will work on 50Hz ?Last edited by EddyCurrent; 28-08-2014 at 01:51 PM.
28-08-2014 #3
I would just run it on 50hz/110v and keep a close eye on the body temp. If it gets warm thats fine, but if it gets hot stop. I have run a porter power router/spindle this way with no problems. Good luck. G.
eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
By Deuce_Coupe in forum Items On eBay UKReplies: 0Last Post: 16-07-2014, 11:46 AM -
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Laminate plastic help!
By totts in forum Marketplace DiscussionReplies: 7Last Post: 13-04-2013, 07:14 PM -
WANTED: Someone to vacuum form and trim a couple simple parts
By matt-b2 in forum Items WantedReplies: 6Last Post: 29-01-2013, 08:35 PM
