29-08-2014 #8
It will allow tool offset's I'm sure of it. Not much good if it doesn't as many machines need tool offsets to work correctly, esp with toolchangers.
The file .nc extension will open in notepad. When you click it to open and get the message saying choose software to open with then use notepad and save as default for this file type.
If you create file in note pad then just replace .txt with .nc and it will work. Both are just plain txt files the .nc extension is nothing special it's just the DSP will be looking for .Nc extension. Chances are it will use .txt as well and just defaults to .nc.?Last edited by JAZZCNC; 29-08-2014 at 10:25 PM.
Opensource machine for dedicated soft tooling?
By gavztheouch in forum Moulding MachinesReplies: 3Last Post: 10-02-2014, 10:27 PM -
Initial thoughts on new build
By Neale in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 25-01-2014, 11:05 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
Best Type of Machine to Build?
By Kevin in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 05-08-2009, 02:50 PM
