    Hi Clive,
    Looks like your version is V6, which is what I have on the actual tooling machine PC.
    This morning I have made progress, in that after talking to Will Stirling, the man who was install and build tech at eMach I have discovered the G code extension should be G-Code Arcs (mm) .tap
    After playing around with axis settings again I have SUCCESSFULLY cut out a letter ! (WOOOT !)
    All I neeed to do now is refine the process to give a better finish and fine tune and I *think* I'm up and running... albeit staggering at the mo LOL!
    This forum is a goldmine of help, and without you guys I might have been tempted to give up before I start... Now I need to get designing and make some stock
    If you can't fix it with a hammer you've got an electrical problem !
    Glad you got it sorted. Its a big high when you do your first successful cut. ..Clive
    Great! I knew it was there the problem. Happy cutting!
  5. #4
    Great stuff and don't be afraid to give stuff ago, if your unsure just set the Z height high at first so it cuts air. Give it Few weeks it will be second nature then in few months you'll be doing stuff that blows your mind.!
    Your problem must have been you wasn't loading G-code and running something in memory because the file extension wouldn't change the actual G-code produced by CAM. This is why I don't like these DSP controllers.? You can't easily see what's happening regards the G-code and machine setup.
    This would have been obvious on Screen with Mach3 or Linux cnc.
    Not saying convert but it's the little things like this that often lead folks to convert.
  1. Opensource machine for dedicated soft tooling?
    By gavztheouch in forum Moulding Machines
    Last Post: 10-02-2014, 10:27 PM
  2. Initial thoughts on new build
    By Neale in forum Gantry/Router Machines & Building
    Last Post: 25-01-2014, 11:05 PM
  3. Some initial questions....
    By andy586 in forum Gantry/Router Machines & Building
    Last Post: 27-01-2013, 03:00 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. Best Type of Machine to Build?
    By Kevin in forum Gantry/Router Machines & Building
    Last Post: 05-08-2009, 02:50 PM
