    Thanks for the reply Neale, and thanks for the advice
    Well I plan to cut aluminium and steel - Mainly to make parts for a new diy cnc - I can see a boring head would be used a lot. I know there is a boring head with a lot of cutters in one of boxes of bits but I haven't checked it out yet.
    Also included was a couple of machine vices, a set of clamping stuff and also a rotary table.
    My inner geek is looking forward to checking out the DRO - Looks really complex and impressive with lights and buttons (no idea what they do...)! The lathe that is coming also has a 2 axis DRO
    Interesting that you have used the threaded end mills with the ER chuck. Have you had any problem with this? I imagine you need to make sure that the collet has enough non-threaded section to grip?
    Possible stupid question, but I cannot see any way to lock the spindle to allow me to change cutters when using the Autolock or the ER32? On both chucks there are no flat spots to put a spanner on? Is this normal?
    Jim
    Even threaded shank cutters have enough plain section for a collet to grip - haven't had a problem (although most of my cutters are plain shank anyway).
    I have a Warco VMC, broadly similar to your machine; I flip the lid open and hold the pulley to "lock" the spindle and that's always worked OK for me.
    DRO's are great. I doubt if I've looked at a dial on my VMC more than a half-dozen times since I've had it. No more losing count when you are moving a couple of inches, trivial picking up centre lines with a wiggler, etc.
    Ah ok thanks, good to know.
    Yes that is what I had to do to release a cutter that was already in the autolock - It was VERY difficult though (took far longer than it should have), could not for the life of me get a good grip on the pulley. Maybe I will get use to it but I think I will try and come up with a easier solution. Maybe I could make a tool to slip over the "cog" part (or maybe one already exists?).
    Wiggler? Is this the tool used to find the edge of the work piece? So to find a centre line I guess you would find the edge of the workpiece with the wiggler, zero the DRO, find the opposite edge and the centre will be half the dro reading?
    Jim
    To unlock a tool, I would hold the spanner in place on the chuck nose and give it a tap with a rubber mallet. The inertia of the drive system means that most of the shock goes into undoing the locking part. Helps if you put the machine in lowest speed as well. Hopefully that's the last time you will need shock tactics, though!
    My DRO lets me "find" an edge with a wiggler. I zero that axis, then pick up the opposite edge. Then there's a "halfway" button on the DRO that sets zero to halfway between the two settings. No arithmetic needed, don't need to know the diameter of the tip of the wiggler, even! Even if you want to zero on an edge, and are going to be using metric coordinates, say, you can pick up the edge with the wiggler, then set the coordinates to half the wiggler diameter (0.25" in my case), and zero is on the edge. Then switch to mm and away you go! So much easier than dials...
  5. The Following User Says Thank You to Neale For This Useful Post:
  6. #5
    Good tip! I suppose the other consideration is tightening the tool...
    Ah I see - Sounds very useful, hopefully my DRO has a similar function. Of to search the internet for a manual!
    I don't suppose you know what is missing from the side of the mill do you? Does your Warco have a similar hole on the side?
  7. #6
    Hi Jim
    Congrats on your new purchase you have a good selection of kit with it and i couldn't see you needing much more, only disadvantage of using ER32 is the posibility of the tool coming loose and marring the collet, the Clarkson tightens the cutter hard into the rear centre so is not an issue, but i am not fortunate enough to have anything so exotic and it seems to work for Neale.
    Happy metal munching
    Mike
  8. #7
    It worried me a bit at first, Mike, as my previous mill had an Autolock-style holder. That was on a 2MT shank, though, so not so useful with an R8 spindle (and having used both, I would have R8 over MT anyday). I haven't done any really heavy cutting, but no problems so far. It does mean that I'm not restricted to screwed shank cutters. I mainly use imperial size cutters and I only have metric ER32 collets, but they seem to grip OK. I have wondered about buying a few specific imperial collets to suit my cutters, just to minimise the closure of the collet and get maximum grip. I could imagine that the Autolock would be better for CNC work, where you might want to change cutters and go back to a known Z height setting; CNC conversion is on the plan but still a fair way off for me!
    Not sure about the hole in the side. Might have been for some kind of switch box? Access to internal wiring? My machine has a removable panel on the back. The Warco version actually has a couple of 1" or so holes at that point, one each side, so that you can stick a bar through to take lifting strops.
    DRO appears to be Newall - decent make, hope you can find a manual for it. It has the 1/2 button for finding mid-lines, so you're in luck there!
  1. Tooling Up advice
    By Mad Professor in forum Tool & Tooling Technology
    Last Post: 22-08-2012, 02:29 PM
  2. Tooling board
    By northmeade in forum Marketplace Discussion
    Last Post: 10-02-2012, 04:17 PM
  3. Tooling
    By p1lts in forum Tool & Tooling Technology
    Last Post: 11-10-2011, 08:14 PM
  4. HSK Tooling
    By Dairsie in forum Tool & Tooling Technology
    Last Post: 02-09-2011, 10:07 PM
  5. BT 35 tooling and DA holders
    Last Post: 19-07-2011, 03:22 PM
